Rover moves at neutral throttle
I have looked a lot but cannot find an answer.
Situation:
Lawn Mower Rover
Remote where the throttle has a forward, neutral, and backward position. The kind of remote with the wheel on the side.
Problem;
When I arm the mower, the vehicle moves forward slowly. But it is moving without any physical throttle input.
Implication:
Uncontrolled lawn mower moving on its. Thankfully, it is moving slowly.
Need:
Is there a way to increase the “band” of neutral for this type of remote?
Trim on the remote and trim on the Rc_Trim creates issues with arming.
Motor deadband makes the problem worse.
I think the neutral range for the remote is somewhere between 1470 and 1490 ppm.
Workaround:
I set up an arm/disarm switch on the remote and disabled motors when disarmed.
Any help would be appreciated. Thank you!!
RC3_DZ. default is 30, but you can increase it. Or decrease it.
Allister,
Thank you for your response. Set to 200 and it did not resolve the issue. It probably isn’t a remote issue, rather a small, unintended, signal coming from the flight controller.
Disarming stops the signal, but not when armed.
Any thoughts?
Either way, thank you for your quick response.
-Allen
Calibrate the RC input and outputs.
I agree with @LupusTheCanine, calibrate the RC inputs (Mission Planner) and the RC outputs (in your radio)
If you’re still having issues there you’ll need to share a .bin log file so somebody can have a closer look to see what’s going on.
What mode is this happening in? Or is it happening in all modes?
Confirmed not a remote issue. Will move even without the remote turned on after arming via mission planner. Happens in Hold and Manual modes.
Also confirmed it is a signal coming from the flight controller by removing the pwm to one wheel. Other wheel moves slowly.
Trying to figure out how to create and download logs.
Ten you need to calibrate the motor controller to Ardupilot signal or adjust Ardupilot output range to match the motor controller range.
Would that be the servo trim setting?
Solved. Reduced servox_min and servox_trim to 900 (1100 default). No longer moves when armed without input!!!
