Rover drift from the waypoint and Data flash log showing the GPS bias from the actual position
I am Currently building an rover , and the rover itself get divert from the mission waypoint , while observing the log there is bias in the GPS location , is this the reason Rover can not trace the path properly , I am attaching the log file link
Yes, you need better GPS signal quality and you need to tune the vehicle so that it follows the desired path better.
I am using CUAV neo 3 pro GPS , and is there advise that you may give regarding tuning
I can’t open your log file. Please unlock the google link.
In which terrain you are driving?
Do the GPS receiver has a clear view to the sky in all directions?
Are there some buildings, trees, hills arround?
Which GNSS system you are using? Sometimes it is better to only use one system.
Try a GPS with RTK, very well supported in Mission Planner.
I have update the google link , Yes there are buildings in right and in the back
I am still not able to reach your log file. The link above still asked for access rights.
