Reset flight statistics without closing and reopening MP
I am looking for a way to reset statistics such as (Time in Air), (Distance Flown) etc. between flights without having to close and reopen Mission Planner each time. Is there a shortcut to reset these values between flights?
Disconnect and reconnect.
Thanks for the tip but I think closing and reopening is actually faster than your method. Closing and reopening is two mouse clicks (autoconnect UDP). Disconnecting and reconnecting is 3-4 mouse clicks. (If I disconnect I have to reselect UDP and click through the port selection). Both methods require all parameters to re-dowload which is the greatest time consumer. Would be very convenient to simply click a button that resets all statistics without having to close and reopen OR disconnect and reconnect.
