Request for Feedback on New Guided Control Mode
Hi all,
I’ve been experimenting with a control concept where horizontal movement is commanded via acceleration targets (X/Y) to improve system responsiveness, while vertical movement is controlled via absolute position (Z). This approach is useful for external guidance systems or reinforcement learning controllers that issue force-like commands for quicker dynamic response.
To test this concept, I created a prototype mode in ArduCopter called AccelXY_PosZ by extending the Guided mode.
Summary of what I implemented:
  • A new GuidedSubMode: AccelXY_PosZ
  • Modified ModeGuided::set_mixed_accelpos() to:
    • Accept X and Y acceleration targets (in m/s²)
    • Accept a Z position target (in cm)
    • Set yaw / yaw_rate optionally
  • Sets PosControl target values accordingly
  • Ignores velocity and Z acceleration
  • Logs are written using existing Log_Write_Guided_Position_Target() API
Here is the prototype branch:
Questions:
  1. Is there a preferred way to structure this kind of control mode?
  2. Is there interest in the community for enabling more flexible control over the type_mask settings in guided mode messages?
Appreciate your time and looking forward to your thoughts!
Thanks,
Portes
Can you rebase your work on top of master? And create a PR? It will be easier to review and comment on.
