Replacement for GoPro mount vibration absorber
My rubber pieces which are around the screws that hold the GoPro mount in the IRIS body broke.
From what I can tell, they are horrible quality and mounting and unmounting the GoPro mount a few times will definitely take it’s toll.
I replaced them with a Silicon Ear Tip for a Headset (amazon.com/Medium-Replacemen … B004WSA1BY) that I had laying around.
Works very well. I even get the impression it works better than the original ones.
Another idea that I had was to use a small O-Ring from the hardware store. Haven’t tried that yet though.
Hope that helps!
Seems like a safer application for rubber inserts. I didn’t realize the stock GoPro mount had these, I never took mine off (no need to… ???).
Just use blue locktite just in case. No telling what will happen to a GoPro when it falls from ~400ft or even higher, nor what will happen to the Iris after suddenly losing the front-end weight… :slight_smile:
replacements for the isolators: hard drive isolators
frozencpu.com/products/8869/ … tX89#blank
Thanks knightrider for this tip!
In the meantime I used some of the Kyosho Zeal gel mat - which I had left over from mounting the Pixhawk - between the front GoPro mount and the frame. This really helped reducing Jello a lot from what I can tell.
Christian
This is a user question and answer support forum, not a discussion forum. I can understand how things can be confusing between this site and DIYDrones, but you are discussing how to make your own modifications to your vehicle and that is a Do It Yourself endeavor. Please try to keep that discussion in the user groups on DIYDrones and come back over here when you have a specific question about how to use your vehicle.
Thanks,
Craig
