Is there better equipment out there, or significantly cheaper sources for the Leah-6H GPS and HMC5883L compass? I’m flying in the US, so I’m not sure if Glonass support would help at all. Basically I have a broken GPS/Compass unit and am searching for the best replacement. Any tips or advice is welcome.
Thanks, MarkM. Any tips on wiring that thing up? I guess I just need a wiring diagram for the stock DR one I have so I could see how to change things up. Some tiny wiring connectors wouldn’t go amiss, either.
edit: Just noticed a 10cm 6-wire JST lead on that CSG Shop site. Probably not long enough, but I could hack the 25cm spare set of leads I have. Disconnects at the GPS and at the Pixhawk just seem convenient, but I suppose aren’t necessary.
[quote=“haygood”]Thanks, MarkM. Any tips on wiring that thing up? I guess I just need a wiring diagram for the stock DR one I have so I could see how to change things up. Some tiny wiring connectors wouldn’t go amiss, either.
edit: Just noticed a 10cm 6-wire JST lead on that CSG Shop site. Probably not long enough, but I could hack the 25cm spare set of leads I have. Disconnects at the GPS and at the Pixhawk just seem convenient, but I suppose aren’t necessary.[/quote]
My bad I put the wrong link up!
drotek.fr/shop/en/home/512-u … mpass.html is the one I have and I was caught out by it as it uses 2x 4pin jst connectors (1mm pitch iirc) all 4 pins for the GPS and 2 of 4 for the compass.
