Hi, I am trying to learn lua scripting for ardupilot for a school project. I’ve tested a script and got error. Then I tought debugging would be better using REPL but I cant connect.The errors can be seen in the images. I’ve tried missionplanner 1.3.74 and 1.3.75 along with different firmware versions of arducopter.
At first try it stuck on “starting REPL”. Then I’ve enabled scr_enable , reboot pixhawk via the temp menu (ctrl+F) and press the connect button. It’s working now thank you for your help. I wish I was able to use in real hardware tho, I think it doesn’t help me much in my current situation.
