Remove or reduce jello effect from video in windy conditons
Hello, I have a copter that flies very well in no wind conditions, good video and everything, but there is a slight problem that I’m experiencing. There is jello effect when flying in winds, my props are balanced, and there is little to no jello effect when no wind is present. I haven’t done autotune, but tuned the copter manually myself.
Would you recommend performing an autotune?
If you can use a small gopro i recommend the gopro 9. the stabilize is realy nice.
I don’t use a gopro, I use sjcam, but I will get a 3 axis gimbal soon, maybe that will fix it, I read that gimbals can mostly fix jello effect
