Recommendation on Optimal Configuration for ArduPlane
I would like to seek your advice regarding the hardware and OS selection for using Ardupilot.
What would you recommend if we have no budget constraints? I am considering purchasing the Pixhawk 6 Pro and using a Jetson running Linux. Do you think this is the optimal choice?
What factors should I take into account? Currently, my primary consideration is ensuring the best compatibility.
Additionally, should I use Docker if I choose Linux? If so, could you please explain the benefits?
Thank you very much for your advice.
Best regards
Double posting that won’t help you.
I didn’t mean to be rude, but as I made a mistake with another post, I couldn’t get the answer I was looking for.
I wanted to delete the former one, but it seems that is not allowed.
I am sorry if I made you feel uncomfortable by making that mistake.
I am a beginner and hope to get the advice I am looking for.
I hope I could have found another way than posting twice, but I was worried about making you feel uncomfortable by asking the same question repeatedly on the same post.
Regards
Without budget constraint that Flight Controller would be a good choice if your application is mission critical enough to warrant the relatively expensive ADIS16470 Industrial IMU. CUAV and Qio-tek have FC’s in that range also.
May I ask one more question if it is doesn’t bother you?
I am using only Linux OS, and I would like to know if using Docker would be the best option in this case.
I appreciate your help and support.
Sorry, I can’t answer that question. I would suggest a new post with Linux OS and Docker in the title. In the General section I suppose.
Your questions are certainly valid but an overly broad post title will often draw little attention.
Oh, you’re right sorry. Thank you for your answers. It helps a lot. Have a nice weekend!
