Rcout through UserCode.cpp
Hi there,
I’m following the RCOutput.cpp example idea and cannot see my PWM output on channel 5. Basically, what I do is
hal.rcout->enable_ch(5);
hal.rcout->write(5, 1050);
in the setup of the UserCode.cpp block,
and in the loop, I am continually just calling the hal.rcout->write(5,1050); function.
I don’t see this value updating in MissionPlanner.
Any ideas what might be the problem? Do I need to configure this channel somehow through MissionPlanner? I thought from the documentation it’s as simple as the steps I am doing.
Try using lua scripting instead of changing the .cpp code. It is simpler and it might work better with mission planner.
I have had the same problem, for future reference, you need to call
hal.rcout->init()
