RCOUT mismatches a lot while arming
I am using ArduCopter 4.6.3. My ESC is DShot. So while I armed the drone RCOUT ( same with rpm) values of 1st pairs of motors and 2nd pairs of motors are different while I am pushing same Mot_Spin_Arm, is it points to worry? or can it degrade the performance of the quadcopter? What is the reason? kindly help.. Thanks in Advance
I am attaching the log also.. https://drive.google.com/file/d/1200GcT5RwI2KkqMvDxbqR76J9edqZQD9/view?usp=sharing
The copter is not level to start with, they never are, the ground is always sloping one way or the other. That output at arming is normal, considering the slight lean.
The correct way to ensure the flight controller knows what is level, is to use a spirit level across the tops of the motors, in each direction possible, and pack under the landing gear until the copter is as good as you can get it, then in MissionPlanner Setup/Mandatory/Accel press “Calibrate Level”
What isn’t normal is the motor outputs during flight.
This is showing some arm or motor-mount twist, since the outputs are grouped by CW and CCW instead of side-to-side or front-to-back, which would indicate a weight imbalance.
But we measure the verticality, it was absolutely fine by checking with sprit level, then why it is happening? I could not understand..
The most irrelevant topic posted on the forum. It’s hardly worth repeating the reason for the 100th time.
So if you went back to root cause as mentioned in ArduCopter document, check the verticality and also then after you are getting the same result.. What should I do?/
The motors don’t need to be level. They need to be the same. Looking at the image of the outputs yours look twisted. Here’s a tool I made to fix it. The pictures will help explain what I’m talking about.
https://www.printables.com/model/1600264-motor-trammel-tool
That tool looks good, I’ll print a set and try it.
I level the motor mounts somewhat like that, before the motors are put on if possible - A lot of motor mounts need the motor fitted first and then affixed to the arm, which is where your tool will come in handy.
