Is it possible to get RCIN and send FrSky telemetry using same UART port? Why use both if they are in different directions?
No, but this is what FPort does I believe
Another problem is the baud rate. I forgot I need two baud rates, one for each direction.
No, you need only F.Port.
What FC do you use?
I have to use PPM (not SBUS) with older FrSky D series receivers so F.Port is not a case.
I am uncertain which board it will ultimately be, as the first one I received had a broken barometer. Today, I should receive another one. H7 for sure.
I will go with two UARTs.
Then you should get your system up to scratch … What sense does PPM make with a new H7 FC?
Let me think … New board for old copter maybe?
I can’t help you there …
I just wonder what sense PPM still makes today if you also want to have telemetry. If then with a current protocol like F.Port or something else like ELRS with CRSF protocol. Using the old stuff forever may appeal to some users, but it’s not really my thing.
