Rc out et walksnail moonlight
bonjour,
j’aimerai savoir comment faire pour démarrer l’enregistrement video de la moonlight a l’aide de commande rc.
merci beacoup
frame 5 pouces
fc holybro h7 mini
Uploading: arducopter 4.6.0 POST TUNE HOLYBRO.param…
Hi @jef38,
Re how to start recording video using an RC command, I think there are two options:
  1. if it is using a RunCam then we have some instructions on the wiki here. The page is a bit messed up but it has this advice
In order to control start and stop of video recording from a radio transmitter set a free rc channel to RCx_OPTION = 78 to enable triggering from that RC input channel. If the switch is in the low position then video recording is stopped, if in the high position then video recording is started.
  1. connect one of the autopilot’s PWM output and connect it to the camera’s pwm input and then use RC pass through by setting SERVOx_FUNCTION = RCxIN. For example if you wanted to use RC 7 to start the video and the autopilot’s Servo output 8 is connected to the camera then you would set SERVO8_FUNCTION = 57 (RCIN7)
FYI @andyp1per
