In one of my copters I found that:
RC_OPTIONS is set to 32
What that means. For what is is used for. I can’t found the description
No it is not.
It is 2^5 means that only Arming check throttle for 0 input
It is the default value.
If you simply click on the value in Mission Planner the Dialog check box that opens will show you what the bit mask value means…
