Hi!
My configuration:
Matek F765 Wing
FrSky R9MM
On early versions of firmware 4.1, No RC Receiver messages often appeared, this did not affect the management in any way. With a certain version of this firmware, instead of this message, the FS mode began to turn on via the throttle channel. The receiver is connected via the FPORT protocol. I tried to switch the receiver to the SPORT+S BUS mode, FS does not turn on in this mode. But if you look at the log, you can see that the data on the channels sometimes take random values. I also tried to change the receiver to X4R, this did not change the situation. The behavior remained the same.
Flight logs are attached:
https://1drv.ms/u/s!AgyvhCRrlh2RmkKjJ26blXa8KFhK?e=ra1ew6
https://1drv.ms/u/s!AgyvhCRrlh2RmkExR1QANUL-_Ple?e=5yTLES
https://1drv.ms/u/s!AgyvhCRrlh2RmkAAayEpQ-emYS2z?e=BUIBFs
