Hi
I have successfully set up a Pi3 with ready to go APSync image and a Pixhawk 2.1 running rover 3.21 and connected through the WiFi hotspot created by the Pi and then UDP through mission planner. I would now like to disable the Wifi connection and instead connect through ethernet but i can not find the files to do so, or anyone else that has done so.
If anyone could run through the steps required, to give the Pi a static ethernet ip address and then how to set mavproxy to output on this ip address that would be great.
Many thanks Martin.
