Raspberry Pi Pixhawk Cube connection
Hi
I am trying to connect raspberry pi 4 to Pixhawk Cube orange via TTL.
I am using /dev/ttyUSB0 and the baud is 57600 and I can’t get a heartbeat.
What am I doing wrong. Please help.
Thank you
Your question is missing a lot of details. Are you using the UART pins on the RPi and a telemetry port on the FC (ttyS0 or ttyAMA0), or a USB cable (ttyACM0), or a USB to UART adapter and a telemetry port (ttyUSB0/1/2…)?
Which software do you use on the RPi?
I am using MAVLink
and the UARTS Pin in RPi 4 directiy to the telem2 port ttyAMA0
hello, would like to ask if you have resolved this?
I connected raspberry pi to cube via usb cable and it worked. Also read this entry, I think you would be able to solve it as well.
You could try connecting through telem ports. You can look the assigned rx tx pins in the telem ports of the cube and connected it to the r-pi’s UART.
The FC on mine is ttyAMA0 and i configured the baudrate to 921600
If I using telem2 port, should the VCC from telem2 connect to TTL?
I think that if you don’t have any power source, you can connect the vcc.
But, to allow the follow of the connection, the ground with each other needs to be connected.
