The offsets are good. Very low actually. Go fly it.
Are you sure sir ???
And QGC ? How to say it’s bad ?
Ask in the QGC thread, I think this thread is done.
Means I don’t understand,
And tomorrow i will go to test this bad guy
Thank you soo much sir
Thank you
Sir I have old apn 2.8 , 2pcs can I remove and fit in pixhawk (compass) is it possible ?
Thank you
Thank you sir for very useful helping , i was successful flight on this day and surprising thing is stabilize mode = althold mode little bit
And I’m sorry for yesterday I’m soo scary about my baby (pixhawk)
This is a today flight with configuration this parameters
RTL is not healthy.
BATT_ARM_VOLT,14.7
BATT_CRT_VOLT,14
BATT_LOW_VOLT,14.4
And these for a bit better tuning, you can safely change these right away:
ATC_THR_MIX_MAN,0.5
PSC_ACCZ_I,0.5
PSC_ACCZ_P,0.25
MOT_BAT_VOLT_MAX,16.8
MOT_BAT_VOLT_MIN,13.2
I’m guessing 9 inch props, these are optional, yours were close but could be better:
ATC_RAT_PIT_FLTD,23
ATC_RAT_PIT_FLTT,23
ATC_RAT_RLL_FLTD,23
ATC_RAT_RLL_FLTT,23
ATC_RAT_YAW_FLTT,23
INS_GYRO_FILTER,46
MOT_THST_EXPO,0.63
And also Thank you Shawn sir
This is morning flight indoor and also try in outdoor but still rtl problem is there but I will check out why this happening.
Thank you
I have problem with Pixhawk and compass identification. I did find for solution, all times see this page, and, for one day, I hope this afirmation was correct, “my pixhawk didn’t have compass too”.
But, if you see the board, you will can find chip DB-5883-900X side by side of local marked in photos, then, have a compass chip !!! model is Three-Axis Digital Compass IC HMC5883L or QMC 5883L - (http://www.farnell.com/datasheets/1683374.pdf).
Different of specifications of Pixhawk Radio Link
thank you,
You add that sensor in your board ?
Answer is Yes , so can you show me how it’s work ?
And what about stability ?
Thank you
I used this firmware and a compass appeared.
http://www.radiolink.com.cn/firmware/Pixhawk/Copter/
or Ardupilot firmware /Copter/stable-3.6.9/fmuv2
Notice about RadioLink PIXHAWK V4.0 Firmware Upgrade
https://radiolink.com.cn/doce/pixhawkv4firmware.html
