I have the same problem with a rover. I moved the antenna, and the lights went from blue to flashing yellow, and the radio disappeared. I can’t get it to calibrate - there’s no bars. i measured the bus voltage, and changed radios - nothing.
Here’s the text file.
ACRO_TURN_RATE,180
AHRS_COMP_BETA,0.1
AHRS_EKF_TYPE,3
AHRS_GPS_GAIN,1
AHRS_GPS_MINSATS,6
AHRS_GPS_USE,1
AHRS_OPTIONS,0
AHRS_ORIENTATION,0
AHRS_RP_P,0.2
AHRS_TRIM_X,0
AHRS_TRIM_Y,0
AHRS_TRIM_Z,0
AHRS_WIND_MAX,0
AHRS_YAW_P,0.2
AIS_TYPE,0
ARMING_ACCTHRESH,0.75
ARMING_CHECK,0
ARMING_CRSDP_IGN,0
ARMING_MAGTHRESH,100
ARMING_MIS_ITEMS,0
ARMING_OPTIONS,0
ARMING_REQUIRE,1
ARMING_RUDDER,2
ARSPD_ENABLE,0
ATC_ACCEL_MAX,1
ATC_BAL_D,0.03
ATC_BAL_D_FF,0
ATC_BAL_FF,0
ATC_BAL_FLTD,0
ATC_BAL_FLTE,10
ATC_BAL_FLTT,0
ATC_BAL_I,1.5
ATC_BAL_IMAX,1
ATC_BAL_LIM_TC,0.5
ATC_BAL_LIM_THR,0.6
ATC_BAL_NEF,0
ATC_BAL_NTF,0
ATC_BAL_P,1.8
ATC_BAL_PDMX,0
ATC_BAL_PIT_FF,0.4
ATC_BAL_SMAX,0
ATC_BRAKE,0
ATC_DECEL_MAX,0
ATC_SAIL_D,0
ATC_SAIL_D_FF,0
ATC_SAIL_FF,0
ATC_SAIL_FLTD,0
ATC_SAIL_FLTE,10
ATC_SAIL_FLTT,0
ATC_SAIL_I,0.1
ATC_SAIL_IMAX,1
ATC_SAIL_NEF,0
ATC_SAIL_NTF,0
ATC_SAIL_P,1
ATC_SAIL_PDMX,0
ATC_SAIL_SMAX,0
ATC_SPEED_D,0
ATC_SPEED_D_FF,0
ATC_SPEED_FF,0
ATC_SPEED_FLTD,0
ATC_SPEED_FLTE,10
ATC_SPEED_FLTT,0
ATC_SPEED_I,0.2
ATC_SPEED_IMAX,1
ATC_SPEED_NEF,0
ATC_SPEED_NTF,0
ATC_SPEED_P,0.2
ATC_SPEED_PDMX,0
ATC_SPEED_SMAX,0
ATC_STOP_SPEED,0.1
ATC_STR_ACC_MAX,120
ATC_STR_ANG_P,2
ATC_STR_RAT_D,0
ATC_STR_RAT_D_FF,0
ATC_STR_RAT_FF,0.2
ATC_STR_RAT_FLTD,0
ATC_STR_RAT_FLTE,10
ATC_STR_RAT_FLTT,0
ATC_STR_RAT_I,0.2
ATC_STR_RAT_IMAX,1
ATC_STR_RAT_MAX,120
ATC_STR_RAT_NEF,0
ATC_STR_RAT_NTF,0
ATC_STR_RAT_P,0.2
ATC_STR_RAT_PDMX,0
ATC_STR_RAT_SMAX,0
ATC_TURN_MAX_G,0.6
AUTO_KICKSTART,0
AUTO_TRIGGER_PIN,-1
AVOID_ACCEL_MAX,3
AVOID_BACKUP_DZ,0.1
AVOID_BACKUP_SPD,0.75
AVOID_BACKZ_SPD,0.75
AVOID_BEHAVE,1
AVOID_ENABLE,3
AVOID_MARGIN,2
BAL_PITCH_MAX,10
BAL_PITCH_TRIM,0
BARO_ALT_OFFSET,0
BARO_EXT_BUS,-1
BARO_FIELD_ELV,0
BARO_FLTR_RNG,0
BARO_GND_TEMP,0
BARO_PRIMARY,0
BARO_PROBE_EXT,0
BARO1_DEVID,721442
BARO1_GND_PRESS,98537.15
BARO1_WCF_ENABLE,0
BARO2_DEVID,721674
BARO2_GND_PRESS,98534
BARO2_WCF_ENABLE,0
BARO3_DEVID,0
BARO3_GND_PRESS,0
BARO3_WCF_ENABLE,0
BATT_MONITOR,0
BATT2_MONITOR,0
BATT3_MONITOR,0
BATT4_MONITOR,0
BATT5_MONITOR,0
BATT6_MONITOR,0
BATT7_MONITOR,0
BATT8_MONITOR,0
BATT9_MONITOR,0
BCN_TYPE,0
BRD_ALT_CONFIG,0
BRD_BOOT_DELAY,0
BRD_HEAT_I,0.07
BRD_HEAT_IMAX,70
BRD_HEAT_LOWMGN,5
BRD_HEAT_P,50
BRD_HEAT_TARG,45
BRD_IO_DSHOT,0
BRD_IO_ENABLE,1
BRD_OPTIONS,1
BRD_PWM_VOLT_SEL,0
BRD_RTC_TYPES,1
BRD_RTC_TZ_MIN,0
BRD_SAFETY_DEFLT,0
BRD_SAFETY_MASK,5
BRD_SAFETYOPTION,0
BRD_SBUS_OUT,0
BRD_SD_FENCE,0
BRD_SD_MISSION,0
BRD_SD_SLOWDOWN,0
BRD_SER1_RTSCTS,2
BRD_SER2_RTSCTS,2
BRD_SERIAL_NUM,0
BRD_TYPE,3
BRD_VBUS_MIN,4.3
BRD_VSERVO_MIN,0
BTN_ENABLE,0
CAM_AUTO_ONLY,0
CAM_MAX_ROLL,0
CAM_RC_TYPE,0
CAM1_TYPE,0
CAM2_TYPE,0
CAN_D1_PROTOCOL,1
CAN_D1_PROTOCOL2,0
CAN_D1_UC_ESC_BM,0
CAN_D1_UC_ESC_OF,0
CAN_D1_UC_ESC_RV,0
CAN_D1_UC_NODE,10
CAN_D1_UC_NTF_RT,20
CAN_D1_UC_OPTION,0
CAN_D1_UC_POOL,16384
CAN_D1_UC_RLY_RT,0
CAN_D1_UC_SER_EN,0
CAN_D1_UC_SRV_BM,0
CAN_D1_UC_SRV_RT,50
CAN_D2_PROTOCOL,1
CAN_D2_PROTOCOL2,0
CAN_LOGLEVEL,0
CAN_P1_BITRATE,1000000
CAN_P1_DRIVER,1
CAN_P1_FDBITRATE,8
CAN_P2_BITRATE,1000000
CAN_P2_DRIVER,1
CAN_P2_FDBITRATE,8
CAN_SLCAN_CPORT,0
CAN_SLCAN_SDELAY,1
CAN_SLCAN_SERNUM,-1
CAN_SLCAN_TIMOUT,0
CIRC_DIR,0
CIRC_RADIUS,20
CIRC_SPEED,0
COMPASS_AUTO_ROT,2
COMPASS_AUTODEC,1
COMPASS_CAL_FIT,16
COMPASS_DEC,0
COMPASS_DEV_ID,97539
COMPASS_DEV_ID2,1313809
COMPASS_DEV_ID3,0
COMPASS_DEV_ID4,0
COMPASS_DEV_ID5,0
COMPASS_DEV_ID6,0
COMPASS_DEV_ID7,0
COMPASS_DEV_ID8,0
COMPASS_DIA_X,1
COMPASS_DIA_Y,1
COMPASS_DIA_Z,1
COMPASS_DIA2_X,1
COMPASS_DIA2_Y,1
COMPASS_DIA2_Z,1
COMPASS_DIA3_X,1
COMPASS_DIA3_Y,1
COMPASS_DIA3_Z,1
COMPASS_DISBLMSK,32
COMPASS_ENABLE,1
COMPASS_EXTERN2,0
COMPASS_EXTERN3,0
COMPASS_EXTERNAL,1
COMPASS_FLTR_RNG,0
COMPASS_LEARN,0
COMPASS_MOT_X,0
COMPASS_MOT_Y,0
COMPASS_MOT_Z,0
COMPASS_MOT2_X,0
COMPASS_MOT2_Y,0
COMPASS_MOT2_Z,0
COMPASS_MOT3_X,0
COMPASS_MOT3_Y,0
COMPASS_MOT3_Z,0
COMPASS_MOTCT,0
COMPASS_ODI_X,0
COMPASS_ODI_Y,0
COMPASS_ODI_Z,0
COMPASS_ODI2_X,0
COMPASS_ODI2_Y,0
COMPASS_ODI2_Z,0
COMPASS_ODI3_X,0
COMPASS_ODI3_Y,0
COMPASS_ODI3_Z,0
COMPASS_OFFS_MAX,1800
COMPASS_OFS_X,0
COMPASS_OFS_Y,0
COMPASS_OFS_Z,0
COMPASS_OFS2_X,-247.823
COMPASS_OFS2_Y,-521.8971
COMPASS_OFS2_Z,-35.3342
COMPASS_OFS3_X,0
COMPASS_OFS3_Y,0
COMPASS_OFS3_Z,0
COMPASS_OPTIONS,0
COMPASS_ORIENT,0
COMPASS_ORIENT2,0
COMPASS_ORIENT3,0
COMPASS_PMOT_EN,0
COMPASS_PRIO1_ID,97539
COMPASS_PRIO2_ID,1313809
COMPASS_PRIO3_ID,0
COMPASS_SCALE,0
COMPASS_SCALE2,0
COMPASS_SCALE3,0
COMPASS_USE,1
COMPASS_USE2,0
COMPASS_USE3,0
CRASH_ANGLE,0
CRUISE_SPEED,2
CRUISE_THROTTLE,50
CUST_ROT_ENABLE,0
DOCK_DIR,-1
DOCK_HDG_CORR_EN,0
DOCK_HDG_CORR_WT,0.75
DOCK_SPEED,0
DOCK_STOP_DIST,0.3
EAHRS_TYPE,0
EFI_TYPE,0
EK3_ABIAS_P_NSE,0.02
EK3_ACC_BIAS_LIM,1
EK3_ACC_P_NSE,0.35
EK3_AFFINITY,0
EK3_ALT_M_NSE,2
EK3_BCN_DELAY,50
EK3_BCN_I_GTE,500
EK3_BCN_M_NSE,1
EK3_BETA_MASK,0
EK3_CHECK_SCALE,100
EK3_DRAG_BCOEF_X,0
EK3_DRAG_BCOEF_Y,0
EK3_DRAG_M_NSE,0.5
EK3_DRAG_MCOEF,0
EK3_EAS_I_GATE,400
EK3_EAS_M_NSE,1.4
EK3_ENABLE,1
EK3_ERR_THRESH,0.2
EK3_FLOW_DELAY,10
EK3_FLOW_I_GATE,300
EK3_FLOW_M_NSE,0.25
EK3_FLOW_USE,1
EK3_GBIAS_P_NSE,0.001
EK3_GLITCH_RAD,25
EK3_GND_EFF_DZ,4
EK3_GPS_CHECK,31
EK3_GPS_VACC_MAX,0
EK3_GSF_RST_MAX,2
EK3_GSF_RUN_MASK,3
EK3_GSF_USE_MASK,3
EK3_GYRO_P_NSE,0.015
EK3_HGT_DELAY,60
EK3_HGT_I_GATE,500
EK3_HRT_FILT,2
EK3_IMU_MASK,7
EK3_LOG_LEVEL,0
EK3_MAG_CAL,2
EK3_MAG_EF_LIM,50
EK3_MAG_I_GATE,300
EK3_MAG_M_NSE,0.05
EK3_MAG_MASK,0
EK3_MAGB_P_NSE,0.0001
EK3_MAGE_P_NSE,0.001
EK3_MAX_FLOW,2.5
EK3_NOAID_M_NSE,10
EK3_OGN_HGT_MASK,0
EK3_OGNM_TEST_SF,2
EK3_POS_I_GATE,500
EK3_POSNE_M_NSE,0.5
EK3_PRIMARY,0
EK3_RNG_I_GATE,500
EK3_RNG_M_NSE,0.5
EK3_RNG_USE_HGT,-1
EK3_RNG_USE_SPD,2
EK3_SRC_OPTIONS,1
EK3_SRC1_POSXY,3
EK3_SRC1_POSZ,1
EK3_SRC1_VELXY,3
EK3_SRC1_VELZ,3
EK3_SRC1_YAW,1
EK3_SRC2_POSXY,0
EK3_SRC2_POSZ,1
EK3_SRC2_VELXY,0
EK3_SRC2_VELZ,0
EK3_SRC2_YAW,0
EK3_SRC3_POSXY,0
EK3_SRC3_POSZ,1
EK3_SRC3_VELXY,0
EK3_SRC3_VELZ,0
EK3_SRC3_YAW,0
EK3_TAU_OUTPUT,25
EK3_TERR_GRAD,0.1
EK3_VEL_I_GATE,500
EK3_VELD_M_NSE,0.7
EK3_VELNE_M_NSE,0.5
EK3_VIS_VERR_MAX,0.9
EK3_VIS_VERR_MIN,0.1
EK3_WENC_VERR,0.1
EK3_WIND_P_NSE,0.1
EK3_WIND_PSCALE,1
EK3_YAW_I_GATE,300
EK3_YAW_M_NSE,0.5
ESC_TLM_MAV_OFS,0
FENCE_ACTION,1
FENCE_ENABLE,0
FENCE_MARGIN,2
FENCE_RADIUS,300
FENCE_TOTAL,0
FENCE_TYPE,6
FFT_ENABLE,0
FILT1_TYPE,0
FILT2_TYPE,0
FILT3_TYPE,0
FILT4_TYPE,0
FILT5_TYPE,0
FILT6_TYPE,0
FILT7_TYPE,0
FILT8_TYPE,0
FLOW_TYPE,0
FLTMODE_GCSBLOCK,0
FOLL_ENABLE,0
FORMAT_VERSION,16
FRAME_CLASS,0
FRAME_TYPE,0
FRSKY_DNLINK_ID,27
FRSKY_DNLINK1_ID,20
FRSKY_DNLINK2_ID,7
FRSKY_OPTIONS,0
FRSKY_UPLINK_ID,13
FS_ACTION,2
FS_CRASH_CHECK,0
FS_EKF_ACTION,1
FS_EKF_THRESH,0.8
FS_GCS_ENABLE,0
FS_GCS_TIMEOUT,5
FS_OPTIONS,0
FS_THR_ENABLE,1
FS_THR_VALUE,910
FS_TIMEOUT,1.5
GCS_PID_MASK,0
GEN_TYPE,0
GPS_AUTO_CONFIG,1
GPS_AUTO_SWITCH,1
GPS_BLEND_MASK,5
GPS_CAN_NODEID1,125
GPS_CAN_NODEID2,0
GPS_COM_PORT,1
GPS_COM_PORT2,1
GPS_DELAY_MS,0
GPS_DELAY_MS2,0
GPS_DRV_OPTIONS,0
GPS_GNSS_MODE,0
GPS_GNSS_MODE2,0
GPS_INJECT_TO,127
GPS_MB1_TYPE,0
GPS_MB2_TYPE,0
GPS_MIN_DGPS,100
GPS_MIN_ELEV,-100
GPS_NAVFILTER,8
GPS_POS1_X,0
GPS_POS1_Y,0
GPS_POS1_Z,0
GPS_POS2_X,0
GPS_POS2_Y,0
GPS_POS2_Z,0
GPS_PRIMARY,0
GPS_RATE_MS,200
GPS_RATE_MS2,200
GPS_RAW_DATA,0
GPS_SAVE_CFG,2
GPS_SBAS_MODE,2
GPS_SBP_LOGMASK,-256
GPS_TYPE,9
GPS_TYPE2,9
GPS1_CAN_OVRIDE,0
GPS2_CAN_OVRIDE,0
GRIP_ENABLE,0
GUID_OPTIONS,0
INITIAL_MODE,0
INS_ACC_BODYFIX,2
INS_ACC_ID,3867682
INS_ACC1_CALTEMP,45
INS_ACC2_CALTEMP,45
INS_ACC2_ID,3867938
INS_ACC2OFFS_X,-0.2469472
INS_ACC2OFFS_Y,-0.1053293
INS_ACC2OFFS_Z,-0.1592846
INS_ACC2SCAL_X,1
INS_ACC2SCAL_Y,1
INS_ACC2SCAL_Z,1
INS_ACC3_CALTEMP,45.25
INS_ACC3_ID,3867658
INS_ACC3OFFS_X,0.1353372
INS_ACC3OFFS_Y,0.01577477
INS_ACC3OFFS_Z,0.062603
INS_ACC3SCAL_X,1
INS_ACC3SCAL_Y,1
INS_ACC3SCAL_Z,1
INS_ACCEL_FILTER,10
INS_ACCOFFS_X,0.1924134
INS_ACCOFFS_Y,0.04124159
INS_ACCOFFS_Z,-0.1570177
INS_ACCSCAL_X,1
INS_ACCSCAL_Y,1
INS_ACCSCAL_Z,1
INS_ENABLE_MASK,127
INS_FAST_SAMPLE,7
INS_GYR_CAL,1
INS_GYR_ID,3867682
INS_GYR1_CALTEMP,44.75
INS_GYR2_CALTEMP,45.0625
INS_GYR2_ID,3867938
INS_GYR2OFFS_X,-0.001787829
INS_GYR2OFFS_Y,0.01035914
INS_GYR2OFFS_Z,0.00228726
INS_GYR3_CALTEMP,47.53125
INS_GYR3_ID,3867658
INS_GYR3OFFS_X,-0.002798521
INS_GYR3OFFS_Y,0.0002224953
INS_GYR3OFFS_Z,-0.00101868
INS_GYRO_FILTER,4
INS_GYRO_RATE,1
INS_GYROFFS_X,-0.001618528
INS_GYROFFS_Y,0.001539781
INS_GYROFFS_Z,-0.0003795047
INS_HNTC2_ENABLE,0
INS_HNTCH_ENABLE,0
INS_LOG_BAT_CNT,1024
INS_LOG_BAT_LGCT,32
INS_LOG_BAT_LGIN,20
INS_LOG_BAT_MASK,0
INS_LOG_BAT_OPT,0
INS_POS1_X,0
INS_POS1_Y,0
INS_POS1_Z,0
INS_POS2_X,0
INS_POS2_Y,0
INS_POS2_Z,0
INS_POS3_X,0
INS_POS3_Y,0
INS_POS3_Z,0
INS_RAW_LOG_OPT,0
INS_STILL_THRESH,0.1
INS_TCAL_OPTIONS,0
INS_TCAL1_ENABLE,0
INS_TCAL2_ENABLE,0
INS_TCAL3_ENABLE,0
INS_TRIM_OPTION,1
INS_USE,1
INS_USE2,1
INS_USE3,1
INS4_ACC_CALTEMP,-300
INS4_ACC_ID,0
INS4_ACCOFFS_X,0
INS4_ACCOFFS_Y,0
INS4_ACCOFFS_Z,0
INS4_ACCSCAL_X,0
INS4_ACCSCAL_Y,0
INS4_ACCSCAL_Z,0
INS4_GYR_CALTEMP,-300
INS4_GYR_ID,0
INS4_GYROFFS_X,0
INS4_GYROFFS_Y,0
INS4_GYROFFS_Z,0
INS4_POS_X,0
INS4_POS_Y,0
INS4_POS_Z,0
INS4_TCAL_ENABLE,0
INS4_USE,1
INS5_ACC_CALTEMP,-300
INS5_ACC_ID,0
INS5_ACCOFFS_X,0
INS5_ACCOFFS_Y,0
INS5_ACCOFFS_Z,0
INS5_ACCSCAL_X,0
INS5_ACCSCAL_Y,0
INS5_ACCSCAL_Z,0
INS5_GYR_CALTEMP,-300
INS5_GYR_ID,0
INS5_GYROFFS_X,0
INS5_GYROFFS_Y,0
INS5_GYROFFS_Z,0
INS5_POS_X,0
INS5_POS_Y,0
INS5_POS_Z,0
INS5_TCAL_ENABLE,0
INS5_USE,1
KDE_NPOLE,14
LOG_BACKEND_TYPE,1
LOG_BITMASK,65535
LOG_DARM_RATEMAX,0
LOG_DISARMED,0
LOG_FILE_BUFSIZE,200
LOG_FILE_DSRMROT,0
LOG_FILE_MB_FREE,500
LOG_FILE_RATEMAX,0
LOG_FILE_TIMEOUT,5
LOG_MAV_BUFSIZE,8
LOG_MAV_RATEMAX,0
LOG_MAX_FILES,500
LOG_REPLAY,0
LOIT_RADIUS,2
LOIT_SPEED_GAIN,0.5
LOIT_TYPE,0
MANUAL_OPTIONS,0
MANUAL_STR_EXPO,0
MIS_DONE_BEHAVE,0
MIS_OPTIONS,0
MIS_RESTART,0
MIS_TOTAL,0
MNT1_TYPE,0
MNT2_TYPE,0
MODE_CH,5
MODE1,10
MODE2,10
MODE3,10
MODE4,10
MODE5,10
MODE6,0
MOT_PWM_FREQ,16
MOT_PWM_TYPE,3
MOT_SAFE_DISARM,0
MOT_SLEWRATE,100
MOT_SPD_SCA_BASE,1
MOT_STR_THR_MIX,0.5
MOT_THR_MAX,100
MOT_THR_MIN,0
MOT_THST_ASYM,1
MOT_THST_EXPO,0
MOT_VEC_ANGLEMAX,0
MSP_OPTIONS,0
MSP_OSD_NCELLS,0
NMEA_MSG_EN,3
NMEA_RATE_MS,100
NTF_BUZZ_ON_LVL,1
NTF_BUZZ_PIN,-1
NTF_BUZZ_TYPES,5
NTF_BUZZ_VOLUME,0
NTF_DISPLAY_TYPE,0
NTF_LED_BRIGHT,3
NTF_LED_LEN,1
NTF_LED_OVERRIDE,0
NTF_LED_TYPES,231
NTF_OREO_THEME,0
OA_TYPE,0
OSD_TYPE,0
PILOT_STEER_TYPE,0
PLND_ENABLED,0
PRX_FILT,0.25
PRX_LOG_RAW,0
PRX1_TYPE,0
PRX2_TYPE,0
PRX3_TYPE,0
PSC_POS_P,0.2
PSC_VEL_D,0
PSC_VEL_FF,0
PSC_VEL_FLTD,5
PSC_VEL_FLTE,5
PSC_VEL_I,0
PSC_VEL_IMAX,1
PSC_VEL_P,1
RALLY_INCL_HOME,1
RALLY_LIMIT_KM,0.5
RALLY_TOTAL,0
RC_OPTIONS,32
RC_OVERRIDE_TIME,3
RC_PROTOCOLS,1
RC1_DZ,30
RC1_MAX,1933
RC1_MIN,1066
RC1_OPTION,0
RC1_REVERSED,0
RC1_TRIM,1498
RC10_DZ,0
RC10_MAX,1932
RC10_MIN,1057
RC10_OPTION,153
RC10_REVERSED,1
RC10_TRIM,1057
RC11_DZ,0
RC11_MAX,1900
RC11_MIN,1100
RC11_OPTION,0
RC11_REVERSED,0
RC11_TRIM,1500
RC12_DZ,0
RC12_MAX,1900
RC12_MIN,1100
RC12_OPTION,0
RC12_REVERSED,0
RC12_TRIM,1500
RC13_DZ,0
RC13_MAX,1900
RC13_MIN,1100
RC13_OPTION,0
RC13_REVERSED,0
RC13_TRIM,1500
RC14_DZ,0
RC14_MAX,1900
RC14_MIN,1100
RC14_OPTION,0
RC14_REVERSED,0
RC14_TRIM,1500
RC15_DZ,0
RC15_MAX,1900
RC15_MIN,1100
RC15_OPTION,0
RC15_REVERSED,0
RC15_TRIM,1500
RC16_DZ,0
RC16_MAX,1900
RC16_MIN,1100
RC16_OPTION,0
RC16_REVERSED,0
RC16_TRIM,1500
RC2_DZ,30
RC2_MAX,1933
RC2_MIN,1066
RC2_OPTION,0
RC2_REVERSED,0
RC2_TRIM,1491
RC3_DZ,0
RC3_MAX,1933
RC3_MIN,1066
RC3_OPTION,0
RC3_REVERSED,0
RC3_TRIM,1931
RC4_DZ,30
RC4_MAX,1933
RC4_MIN,1066
RC4_OPTION,0
RC4_REVERSED,0
RC4_TRIM,1495
RC5_DZ,0
RC5_MAX,1933
RC5_MIN,1066
RC5_OPTION,0
RC5_REVERSED,0
RC5_TRIM,1066
RC6_DZ,0
RC6_MAX,1933
RC6_MIN,1066
RC6_OPTION,0
RC6_REVERSED,0
RC6_TRIM,1561
RC7_DZ,0
RC7_MAX,1933
RC7_MIN,1066
RC7_OPTION,34
RC7_REVERSED,0
RC7_TRIM,1933
RC8_DZ,0
RC8_MAX,1933
RC8_MIN,1066
RC8_OPTION,28
RC8_REVERSED,0
RC8_TRIM,1510
RC9_DZ,0
RC9_MAX,1933
RC9_MIN,1066
RC9_OPTION,51
RC9_REVERSED,0
RC9_TRIM,1066
RCMAP_PITCH,3
RCMAP_ROLL,1
RCMAP_THROTTLE,2
RCMAP_YAW,4
RELAY1_DEFAULT,0
RELAY1_FUNCTION,5
RELAY1_PIN,54
RELAY2_DEFAULT,0
RELAY2_FUNCTION,6
RELAY2_PIN,55
RELAY3_FUNCTION,0
RELAY4_FUNCTION,0
RELAY5_FUNCTION,1
RELAY6_FUNCTION,1
RNGFND1_TYPE,0
RNGFND2_TYPE,0
RNGFND3_TYPE,0
RNGFND4_TYPE,0
RNGFND5_TYPE,0
RNGFND6_TYPE,0
RNGFND7_TYPE,0
RNGFND8_TYPE,0
RNGFND9_TYPE,0
RNGFNDA_TYPE,0
RPM1_TYPE,0
RPM2_TYPE,0
RSSI_TYPE,0
RST_SWITCH_CH,0
RTL_SPEED,0
SAIL_ENABLE,0
SCHED_DEBUG,0
SCHED_LOOP_RATE,50
SCHED_OPTIONS,0
SCR_ENABLE,0
SERIAL_PASS1,0
SERIAL_PASS2,-1
SERIAL_PASSTIMO,15
SERIAL0_BAUD,115
SERIAL0_PROTOCOL,2
SERIAL1_BAUD,57
SERIAL1_OPTIONS,0
SERIAL1_PROTOCOL,2
SERIAL2_BAUD,57
SERIAL2_OPTIONS,0
SERIAL2_PROTOCOL,2
SERIAL3_BAUD,230
SERIAL3_OPTIONS,0
SERIAL3_PROTOCOL,5
SERIAL4_BAUD,230
SERIAL4_OPTIONS,0
SERIAL4_PROTOCOL,5
SERIAL5_BAUD,57
SERIAL5_OPTIONS,0
SERIAL5_PROTOCOL,1
SERIAL6_BAUD,115200
SERIAL6_OPTIONS,0
SERIAL6_PROTOCOL,22
SERVO_32_ENABLE,0
SERVO_BLH_3DMASK,0
SERVO_BLH_AUTO,0
SERVO_BLH_DEBUG,0
SERVO_BLH_MASK,0
SERVO_BLH_OTYPE,0
SERVO_BLH_POLES,14
SERVO_BLH_PORT,0
SERVO_BLH_RVMASK,0
SERVO_BLH_TEST,0
SERVO_BLH_TMOUT,0
SERVO_BLH_TRATE,10
SERVO_DSHOT_ESC,0
SERVO_DSHOT_RATE,0
SERVO_FTW_MASK,0
SERVO_FTW_POLES,14
SERVO_FTW_RVMASK,0
SERVO_GPIO_MASK,0
SERVO_RATE,50
SERVO_RC_FS_MSK,0
SERVO_ROB_POSMAX,4095
SERVO_ROB_POSMIN,0
SERVO_SBUS_RATE,50
SERVO_VOLZ_MASK,0
SERVO1_FUNCTION,73
SERVO1_MAX,2000
SERVO1_MIN,1000
SERVO1_REVERSED,0
SERVO1_TRIM,1000
SERVO10_FUNCTION,0
SERVO10_MAX,1900
SERVO10_MIN,1100
SERVO10_REVERSED,0
SERVO10_TRIM,1500
SERVO11_FUNCTION,0
SERVO11_MAX,1900
SERVO11_MIN,1100
SERVO11_REVERSED,0
SERVO11_TRIM,1500
SERVO12_FUNCTION,0
SERVO12_MAX,1900
SERVO12_MIN,1100
SERVO12_REVERSED,0
SERVO12_TRIM,1500
SERVO13_FUNCTION,0
SERVO13_MAX,1900
SERVO13_MIN,1100
SERVO13_REVERSED,0
SERVO13_TRIM,1500
SERVO14_FUNCTION,0
SERVO14_MAX,1900
SERVO14_MIN,1100
SERVO14_REVERSED,0
SERVO14_TRIM,1500
SERVO15_FUNCTION,0
SERVO15_MAX,1900
SERVO15_MIN,1100
SERVO15_REVERSED,0
SERVO15_TRIM,1500
SERVO16_FUNCTION,0
SERVO16_MAX,1900
SERVO16_MIN,1100
SERVO16_REVERSED,0
SERVO16_TRIM,1500
SERVO2_FUNCTION,0
SERVO2_MAX,1900
SERVO2_MIN,800
SERVO2_REVERSED,0
SERVO2_TRIM,800
SERVO3_FUNCTION,74
SERVO3_MAX,2000
SERVO3_MIN,1000
SERVO3_REVERSED,0
SERVO3_TRIM,1000
SERVO4_FUNCTION,0
SERVO4_MAX,1900
SERVO4_MIN,1100
SERVO4_REVERSED,0
SERVO4_TRIM,1500
SERVO5_FUNCTION,0
SERVO5_MAX,1900
SERVO5_MIN,1100
SERVO5_REVERSED,0
SERVO5_TRIM,1500
SERVO6_FUNCTION,0
SERVO6_MAX,1900
SERVO6_MIN,1100
SERVO6_REVERSED,0
SERVO6_TRIM,1500
SERVO7_FUNCTION,0
SERVO7_MAX,1900
SERVO7_MIN,1100
SERVO7_REVERSED,0
SERVO7_TRIM,1500
SERVO8_FUNCTION,0
SERVO8_MAX,1900
SERVO8_MIN,1100
SERVO8_REVERSED,0
SERVO8_TRIM,1500
SERVO9_FUNCTION,135
SERVO9_MAX,1900
SERVO9_MIN,1100
SERVO9_REVERSED,0
SERVO9_TRIM,1500
SIMPLE_TYPE,0
SPEED_MAX,0
SPRAY_ENABLE,0
SR0_ADSB,0
SR0_EXT_STAT,2
SR0_EXTRA1,4
SR0_EXTRA2,4
SR0_EXTRA3,2
SR0_PARAMS,10
SR0_POSITION,2
SR0_RAW_CTRL,1
SR0_RAW_SENS,2
SR0_RC_CHAN,2
SR1_ADSB,0
SR1_EXT_STAT,1
SR1_EXTRA1,1
SR1_EXTRA2,1
SR1_EXTRA3,1
SR1_PARAMS,10
SR1_POSITION,1
SR1_RAW_CTRL,1
SR1_RAW_SENS,1
SR1_RC_CHAN,1
SR2_ADSB,0
SR2_EXT_STAT,1
SR2_EXTRA1,1
SR2_EXTRA2,1
SR2_EXTRA3,1
SR2_PARAMS,10
SR2_POSITION,1
SR2_RAW_CTRL,1
SR2_RAW_SENS,1
SR2_RC_CHAN,1
SR3_ADSB,0
SR3_EXT_STAT,1
SR3_EXTRA1,1
SR3_EXTRA2,1
SR3_EXTRA3,1
SR3_PARAMS,10
SR3_POSITION,1
SR3_RAW_CTRL,1
SR3_RAW_SENS,1
SR3_RC_CHAN,1
SR4_ADSB,0
SR4_EXT_STAT,1
SR4_EXTRA1,1
SR4_EXTRA2,1
SR4_EXTRA3,1
SR4_PARAMS,10
SR4_POSITION,1
SR4_RAW_CTRL,1
SR4_RAW_SENS,1
SR4_RC_CHAN,1
SRTL_ACCURACY,2
SRTL_OPTIONS,0
SRTL_POINTS,300
STAT_BOOTCNT,5
STAT_FLTTIME,729
STAT_RESET,1
STAT_RUNTIME,28367
STICK_MIXING,0
SYSID_ENFORCE,0
SYSID_MYGCS,255
SYSID_THISMAV,1
TELEM_DELAY,0
TRQD_TYPE,0
TURN_RADIUS,0.9
VISO_TYPE,0
VTX_ENABLE,0
WENC_TYPE,0
WNDVN_TYPE,0
WP_ACCEL,0
WP_JERK,0
WP_PIVOT_ANGLE,60
WP_PIVOT_DELAY,0
WP_PIVOT_RATE,60
WP_RADIUS,2
WP_SPEED,2
WRC_ENABLE,0
