I use Mini Pix board on the airplane V3.9 also I setup mini osd with telemetry. Unfortunately When I switch on the radio control which uses 433hrz long distance TX rx OSD`s datas lost from the screen. The radio control effected negatively data of the osd. How can I solve this problem…
double check you have your OSD’s screen switch channel setup correctly. possibly it’s an unfortunate channel setting that blanks your OSD screen once the transmitter is switched on.
thank you it was very useful for me… regards
