so i have a quadcopter config, basically l wanted to reset the pixi so i flashed the rover firmware then flashed the quadcopter one after, then as i was calibrating the steps (accel cal, compass, etc) i came to the radio calibration part and im moving the sticks on the remote but its not working even tho the remote is telling me its connected to the reciver and the reciver is flashing well saying its connected , yet i move the sticks and its not registering not on the drone motors nor on mission planner itself (i was testing it numorous times before reseting and it always worked so i dont think its a past problem)
thanks in advance
IIRC ELRS receivers don’t blink when connected, you also need to configure serial for RCIN or MAVLink2 to use CRSF or MAVLink respectively as a way for comunicating with the receiver.
