Hello, I want to connect 2 siyi R1M camera for MK32. so I tried to change ip address first one(second one is keep default ip).
I read the documentation, downloaded the firmware bin, put it in the sd card, booted, waited 3-5 minutes, disconnected, took it out and checked.
but no matter how many times I try, the text file with the ip address is not written.
The firmware bin was cleared, so I assume the update itself was successful.
Of course, the address was not changed, so I created my own curip.txt and setip.txt files and placed them, but the ip address was not changed.
What can I do from here to update the IP address? Is there a new document that has not been released yet?
Please format the SD card and do not insert firmware.
Turn off R1M, insert SD card, then power on R1M and wait for 2 minutes.
Usually, after removing the SD card, a. txt file with IP address modification can be seen.
Thank you for your reply, I formatted the SD card and stuck it in again to standby, but it still did not write the ip address and only recorded in the record folder. I don’t think it has anything to do with the video files being written, but are there any restrictions on the format of the SD card or the standard of the SD card (HC/XC, etc.)? I am currently using a 128GB SDXC, formatted as exFAT.
Solved: it’s SD issue, so I need to use another SDHC,fat32 formatted Card.
…Why does it work for non-text files? That just makes me even more confused… by the way, this problem was solved. thanks.
