Quadrotor cuav7+pro
Hello
My drone is having some problems, can you help me?
My drone is vibrating a lot on the x-axis, what is the problem?
And the second thing is, as soon as the mission command is given, up to an altitude of about 700 to 1000 meters, nothing changes on the ground screen, except for one or two degrees, but from this height, the drone gradually tilts to one side, up to about 10 to 20 degrees, which shows that it is tilted to one side and we do not reach the speed we intended and it flies at a lower speed, and when it lands again, it reaches an altitude of about a thousand meters, it starts to correct itself again and the screen becomes flat.
Three issues
  1. built it better. The documentation provides guidelines on how to built it better so that it vibrates less.
  2. Configure it correctly. Again use the documentation and configure it correctly. Configure each sensor and each actuator to the best of your abilities, don’t be lazy the documentation is your best friend.
  3. Once that is done post a .bin file of a single flight where you have issues. Without it we can not guess what the issue is.
Does this make sense to you?
You shouldn’t be flying any missions then.
Without a .bin file there is no way to help. Listen to @dkemxr @amilcarlucas their advice.
