QuadPlane: Unable to Resume AUTO Mission After VTOL Landing (Auto Re-arm & Takeoff Issue)
Hi everyone,
I’m currently working with a QuadPlane in ArduPilot and facing an issue with mission continuation after a VTOL landing.
My goal:
I want the aircraft to perform a VTOL landing during an AUTO mission, then automatically re-arm and continue the remaining mission (including takeoff).
Problem:
After the VTOL landing is completed, the aircraft disarms as expected, but it does not proceed with the rest of the mission. It does not perform an automatic re-arm or AUTO takeoff.
What I’ve tried so far:
  • Used DELAY mission item
  • Used DO_AUX_FUNCTION to attempt re-arming / triggering actions
  • Experimented with mission flow adjustments
However, none of these approaches are working — the vehicle remains disarmed and the mission does not resume.
What I’m looking for:
  • Is there a supported way to automatically re-arm after a VTOL landing in a mission?
  • Can this behavior be achieved using mission commands alone, or is a Lua script required?
  • If Lua is needed, what would be the recommended approach for safely re-arming and resuming the mission?
Any guidance, examples, or parameter suggestions would be greatly appreciated.
Thanks in advance!
Can you share your mission file and parameters?
