Quadcopter kept spinning but won't go further
Hello, everone! :waving_hand: I am working on object-avoidance copter with BendyRuler(vertical) in auto mode recently, on my real flight experiment, the copter would not go further but just spinning, as if it was hesitating where to go. It happened from time to time. Environment related I guess.
I have read the code AP_OABendyRuler.cpp but could not get the solution for the spinning. Can someone help me? Thanks a lot. :sparkling_heart:
Firmware: Copter-4.6.2
Flight Controller: Pixhawk 6c mini
Object-avoidance method: vertical BendyRuler
Object-avoidance related paramters:
OA_BR_CONT_ANGLE,75
OA_BR_CONT_RATIO,1.5
OA_BR_LOOKAHEAD,10
OA_BR_TYPE,2
OA_DB_ALT_MIN,0
OA_DB_BEAM_WIDTH,5
OA_DB_DIST_MAX,0
OA_DB_EXPIRE,10
OA_DB_OUTPUT,3
OA_DB_QUEUE_SIZE,80
OA_DB_RADIUS_MIN,0.01
OA_DB_SIZE,100
OA_MARGIN_MAX,4
OA_OPTIONS,1
OA_TYPE,1
Experiment video:https://youtu.be/WcOL2EVchdw
Share the .bin log for the flight.
Thanks for reply, Allister. :smiley: The file is too big to upload. This is the link to the bin file:https://drive.google.com/file/d/1GJe0reIxxf-eD0Z_x9X0_hCZdzAEANHK/view?usp=sharing
The download link needs a password. You’ll need to remove the password.
My bad. @Allister I have removed the password, anyone who gets the link can download the file, there is no need to log in right now.
What kind of sensors were you using for OA? How are they set up on the drone?
Just thinking about this some more, it looks like the OA was being triggered. The mission height was low and with the trees that might have been enough to trigger things. As you said, “environmental”.
I’am using one Hexsoon 77G 40M MWW Radar as supported by ardupilot Hexsoon 77G MWW Radar — Copter documentation. And the radar is placed in front of the frame
Yeah, I also think the OA was triggered. But the drone could have went up to avoid the trees because I set the avoidance strategy to vertical. It seems like the drone awared that there are trees among it, but it could not find a way out.
BTW, what analysis software are you using to analyze the bin file?
I’ve never used the vertical mode so I’ll try to do some digging.
The software is MavExplorer.
got it!thanks for sharing.
