Quad X motor rotation opposite of ArduPilot diagram
I am building my first quadcopter using ArduPilot (Copter 4.6) on a Pixhawk 6C.
Frame type is Quad X. Motor numbering and output order are correct and verified in Mission Planner using the motor test.
However I noticed that my motor rotation pattern is the mirror image of the standard ArduPilot diagram.
My setup is:
Front right: CW motor
Rear right: CCW motor
Rear left: CW motor
Front left: CCW motor
So effectively:
Front left: CCW
Front right: CW
Rear left: CW
Rear right: CCW
This is the exact opposite rotation direction of the standard Quad X layout, but the motors are still arranged diagonally (2 CW and 2 CCW).
Important details:
  • Motors: BR2212 980KV with self-tightening CW/CCW threaded shafts
  • Props therefore cannot easily be swapped
  • Motor order is correct (A,B,C,D)
  • Props produce thrust downward
  • The drone actually flew stable during a short hover test, only a small drift in stabilize mode.
My question:
Is there any downside in ArduPilot to running the mirror motor rotation pattern, or is it perfectly acceptable as long as torque balance is maintained?
I am mainly wondering if this could affect:
  • yaw control
  • autotune
  • PID behaviour
Or if ArduPilot handles both patterns equally well.
Just choose the QUAD H frame type. Despite being labeled as an H frame, the only difference under the hood is motor rotation.
You will run into significant issues with yaw direction otherwise.
FWIW, when I had motors spinning in the opposite direction in ArduPilot, I temporarily connected the ESCs to a BetaFlight flight controller and reversed the motors from within BetaFlight.
I personally prefer the BetaFightXReversed frame type.
FRAME_TYPE = 18. I find the reversed props can handle small twigs and grass much better than the normal rotation direction.
Yep, that’s the exact same motor scheme as QUAD H with slightly different output numbering to hopefully make it easier to route wires to 4in1 ESCs. The net result is identical.
