Quad plane engine configuration H
Hi everyone, I’m trying to build a Quad-Plane with 2 fixed and two tilting (vector) motors.
I ran the configuration described by default:
Can 5, servo_function 33 Motor1
Can 6, servo_function 34 Motor2
Can 7, servo_function 35 Motor3
Can 8, servo_function 36 Motor4
Can 9, servo_function 76 Tilt servo DX
Can 10, servo_function 75 Tilt servo SX
When I turn the aircraft on manually, the engines 1 (frontDX) and 2 (rearSX) are turned on and the front engines lean forward.
When I move the switch to Q-stabilize the front engines get up and all 4 start.
If I pass in FBWA the motors tilt forward, the motors 1 (frontDX) and 2 (rearSX) remain on while the 3(frontSX) and 4(rearDX) go off.
In hovering in Q-stabilize the quad_plane remains stable but when I change in FBWA it does not fly.
Where do you think I went wrong?
Thanks as of now.
