Note that the big hole in the disc does not actually fit over the motor spindle, it’s too small in diameter. :-S
Right. Remove the thread adapter. Well perhaps not. Those came with a 3 bolt thread adapter And a t-style washer? Hopefully there are some tapped holes that align with the washer clearance holes. If not I don’t know what you have.
Website blurb says “each motor also comes with a direct mounting prop adapter so that you can use our direct mount propellers with this motor”
Take off the prop adapter and see if there are tapped holes in the motor that line up with the washer. If so, buy T-style props. You get this right? Props fit on and pilot on the center hole. Washer goes on over that and the 2 screws, usually M3, secure it.
Yes, there do appear to be what you say:
Thanks for the tip. If/when I knacker these props I will go straight to the T-style and disable non damped mode.
Please feel free to download the flight log from below:
It’s a zip. Password is my username. Thanks.
