Hi. I am new to the quadcopter. I started flying a cheap quad copter and have build a larger quad copter and can not get it to behave the same. Regardless of what way I move the pitch, it always moves forward. I want to be able to pull back on the pitch and have it fly backwards, when I push forward on the stick, I want it to move forward. That way if I am flying into the side of my house, I don’t have to turn it around 180 degrees to avoid the disaster…
I assume this is possible, but I can not find the setting for this anywhere or I don’t understand what its called.
I am currently configured in the + configuration, but I am thinking of going with the x configuration since that is how my cheap quad flies and I like that a little better. I have a ton of other questions, but I just want to get this fixed and then I will start trying to figure out the rest.
Thanks,
Charlie
