Qio-tek ASP 5033 Airspeed sensor jumps to 20m/s in the room with F405-WMN
I bought a Qio-tek ASP 5033 Airspeed sensor and had asked for a replace, the problem happened both on the replace one and the first one.
I am in in-door condition so there is no wind. The sensor value just jumps from 0m/s to 20m/s. Preflight calibration doesn’t address it.
After I switched to FDRC airspeed sensor the problem is gone. I guess it’s because Qio-tek ASP 5033 Airspeed sensor is not compatible with F405-WMN. Have everyone else tried this two working together?
I still want to use 5033 because it’s much cheaper than the FDRC one.
Any one has the same problem?
