I am trying to make a pymavlink script that would test all the motors of my drones. I have one bluerobotics bluerov2 and and small usv with two motors with ardurover.
I tryied to use master.mav.command_long_send messages, ether in pwm or percentage of throttle but it never worked as expected.
Did anyone ever succeeded making motor tests with pymavlink ?
I tried to connect to the drone and set 20% of throttle for 2s.
#!/usr/bin/env python3
Script simple pour tester tous les moteurs d'un drone ArduSub
Se connecte en UDP sur le port 14550 et teste chaque moteur à 20% pendant 2s
from pymavlink import mavutil
import time
import sys
# Configuration
UDP_PORT = 14550
THROTTLE_POURCENTAGE = 20
DUREE_TEST = 2 # secondes
PAUSE_ENTRE_MOTEURS = 0.5 # secondes
def connecter_drone():
"""Se connecte au drone via UDP"""
print("Connexion au drone via UDP...")
print(f"Port: {UDP_PORT}")
try:
master = mavutil.mavlink_connection(f"udpin:0.0.0.0:{UDP_PORT}")
print("Attente du heartbeat...")
master.wait_heartbeat(timeout=10)
target_system = master.target_system
print(f"✓ Connecté au système {target_system}")
return master, target_system
except Exception as e:
print(f"✗ Erreur de connexion : {e}")
sys.exit(1)
def tester_moteur(master, target_system, numero_moteur, throttle_pourcentage, duree):
# Calcul PWM: 1500 (neutre) + pourcentage * 4
throttle_pwm = 1500.0 + (throttle_pourcentage * 4.0)
while master.recv_match(type='COMMAND_ACK', blocking=False, timeout=0.1):
pass
# Envoi de la commande de test moteur
master.mav.command_long_send(
target_system,
master.target_component,
mavutil.mavlink.MAV_CMD_DO_MOTOR_TEST,
0,
float(numero_moteur - 1), # ArduSub utilise 0-7, on envoie donc n-1
float(mavutil.mavlink.MOTOR_TEST_THROTTLE_PWM),
float(throttle_pwm),
float(duree),
float(1),
float(mavutil.mavlink.MOTOR_TEST_ORDER_BOARD),
float(0)
# Attente de l'ACK
timeout_start = time.time()
while time.time() - timeout_start < 3:
msg = master.recv_match(blocking=True, timeout=0.5)
if msg and msg.get_type() == 'COMMAND_ACK':
if msg.command == mavutil.mavlink.MAV_CMD_DO_MOTOR_TEST:
if msg.result == mavutil.mavlink.MAV_RESULT_ACCEPTED:
print("✓")
return True
else:
print(f"✗ (code: {msg.result})")
return False
print("⚠ (pas de confirmation)")
return False
def main():
# Connexion
master, target_system = connecter_drone()
# Confirmation
print("\n⚠️ ATTENTION: Assurez-vous que les hélices sont retirées!")
reponse = input("\nLancer le test de tous les moteurs ? (o/n): ")
if reponse.lower() != 'o':
print("Test annulé.")
master.close()
return
# Compte à rebours
print("\nDémarrage dans 3 secondes...")
time.sleep(3)
# Test de tous les moteurs
print("\n" + "=" * 60)
print(" TEST EN COURS")
print("=" * 60)
succes = 0
echecs = 0
for moteur in range(1, 9):
print(f"\n[{moteur}/8]", end=" ")
if tester_moteur(master, target_system, moteur, THROTTLE_POURCENTAGE, DUREE_TEST):
succes += 1
else:
echecs += 1
# Pause avant le moteur suivant (sauf pour le dernier)
if moteur < 8:
time.sleep(DUREE_TEST + PAUSE_ENTRE_MOTEURS)
else:
time.sleep(DUREE_TEST) # Pas de pause après le dernier
# Résumé
print(" RÉSUMÉ")
print("=" * 60)
print(f"Tests réussis: {succes}/8")
print(f"Tests échoués: {echecs}/8")
print("=" * 60)
# Fermeture
print("\nFermeture de la connexion...")
master.close()
print("✓ Terminé")
if __name__ == "__main__":
try:
main()
except KeyboardInterrupt:
print("\n\n⚠️ Interruption par l'utilisateur (Ctrl+C)")
sys.exit(0)
