I was trying to do some individual motor tests to be able to autonomously control the motors on the AUX pins of the Orange CubePilot controller, but I can’t seem to be able to test the motors or even arm the device. It returns a MAV_RESULT of 1, meaning temporarily rejected, because I assume it can’t get a GPS lock, as it is just 2 motors attached to a battery and the Cube. Is there a way of overriding this?
For reference here is my code:
from pymavlink import mavutil
import time
# Connect to the flight controller
# Replace '/dev/tty.usbmodem01' with the correct serial port
# master = mavutil.mavlink_connection('localhost:14445')
# master = mavutil.mavlink_connection('/dev/tty.usbmodem01', baud=57600)
master = mavutil.mavlink_connection('/dev/cu.usbmodem01')
# Wait for a heartbeat to confirm the connection
master.wait_heartbeat()
print("Heartbeat received! Flight controller is connected.")
master.mav.command_long_send(master.target_system, master.target_component,
mavutil.mavlink.MAV_CMD_COMPONENT_ARM_DISARM, 0, 1, 0, 0, 0, 0, 0, 0)
msg = master.recv_match(type="COMMAND_ACK", blocking=True)
print(msg)
# master.mav.command_long_send(master.target_system, master.target_component,
# mavutil.mavlink.MAV_CMD_DO_MOTOR_TEST, 0, 5, 1, 1500, 15,
# 0, 0, 0)
And here is what I am getting when I rude the code (in terminal)
COMMAND_ACK {command : 400, result : 1, progress : 0, result_param2 : 0, target_system : 255, target_component : 0}
My end goal is to be able to run the motors autonomously without using tols like QGroundControl of another GUI system. I would like to be able to run commands independently. But for now if I could even supply code to the QGC system to make it run without using the actuator bars that would be great.
