I have a component which gives PWM signal. I want to give this as an input to pixhawk cube orange through one of the servo pins. And the pixhawk should convert this to a relay and emit on one of the auxiliary pins. I know it can be done externally through a pwm to relay converter. But want to avoid too many components on my drone.
Ask : Is there a way we can do this? if yes, can someone please guide me.
You could call the “component” a Fuel Level sensor. There is support for PWM out versions. Not sure how you would trigger a relay from this, Lua Script maybe.
If you can read it as a “battery sensor” wich has support for pwm input than with lua you could switch relay you need on or off based on pwm input.
