Pwm And RPM Issue (Solved-There is no issue)
We are using ArduPilot v4.6.2 with BDShot firmware and DShot 300 ESCs. During ground testing (no propellers), after arming the drone and increasing throttle to about 50%, the motor PWM did not vary — it stayed between 1100–1200 . When the throttle was increased above ~50%, PWM jumped directly from ~1100 to ~1800+. All motor/ESC-related parameters are at their default values. However, during flight testing the drone took off and hovered correctly at expected PWM values.
Motor: Machtech DM7006 340KV
ESC: APD ESC 80A
Propeller: 28 inch
Drone maximum weight: 10 kg
Operating modes tested: Stabilize, AltHold
That is normal, because without props, you are testing a closed loop control system in an open-loop configuration. So it just behaves like that.
Once you put props on it and let it fly, it closes the control loop and things start to work as expected.
