UPDATE: It worked. After almost two hours of various attempts at reducing interference and turning the vehicle around its axes until my neck was stiff, the compass is finally calibrated.
Hello, I am using a TT-02 Chassis by Tamiya with a Pixhawk 4. I have installed the latest ArduRover firmware, and I’m using QGroundControl as a ground control station.
When trying to calibrate the compass, I constantly receive a Mag(0) bad orientation error, causing the calibration to fail.
I have already removed any electronics that could cause interference to the compass, and I am not using the internal compass.
Does anyone have an idea of what is causing the problem?
Thank you already in advance for your help!
Greetings,
Julia
