Hi! This is my first post here! I am having my first APM 2.6 on my hands and I am facing some problems.
Firstly I am using an FrSky X8R receiver and I want to use the RSSI output. I connect everything by following those instructions here: copter.ardupilot.com/wiki/common … ndication/ but I can’t find anywhere in the latest Mission Planner the RSSI_RANGE! Where is this parameter?
Secondly, I was trying to activate the relay! I setup CH7 from my transmitter and from the Mission Planner I change the Relay_Pin to A9 and from running I’ve set the CH7 to Relay On/Off. But nothing is happening! I’ve check with the Mission Planner (from the radio calibration section) and CH7 is going above the defined PWM value! How I will activate the relay from my transmitter switch? What I am doing wrong?
