Problems loading parameters after I updated to version 4.1.5
I am using AP version 4.1.5 on four Pixhawk Mini4 in TradHelis.
Until the update to version 4.1.5 I had no
problems loading parameters from FC into Mission Planner.
After I updated to 4.1.5, on all four FCs I have the problem that loading the parameters takes a long time.
By chance I have activated the parameter FFT_, for anlayzing the vibrations. And, the parameters are then loaded quickly again. If I deactivate FFT_ again, the problem with the slow loading is back.
I have made a Youtube video about this, where you can follow this behavior on the MP.
What can be the reason for this?
BR
Heri
There is a fix for this in 4.2 - you should try it
Hi Andy,
is it this bug fix in 4.2.2 ?
“f) Param download (via MAVFTP) fixed for params with overlapping names”
If so, I will wait until I use 4.2.2.
In the moment i do not update to 4.2.2 because, with a trad heli you have to retune the min an max parameters of the collective pitch. In the moment I want to fly because we have good weather in Germany. In Winter ist better to work on the helis :wink:
BR
Heri
