Hello dear friends
I am involved in a project which use to control a rc car with pixhawk 4 ardurover.
my speed cotnroller is Hobeywing max 8 150 A which supports braking and reverse mode.
in order to start using this esc, I need first to center the throttle (if I directly connect the receiver to the esc) turn the esc on and then move the throttle to most forward and most backward position so the esc gets the definition of each throttle postion.
As I need to connect the esc in to pixhawk output for my project, what I did for callibrating it was to swithch in to manual mode, arm the pixhawk center the throttle, turning on the esc, pushing throttle most forward and then most backward. it then callibrated and now it works fine.
the problem rose when I switched in to steering mode. in this mode vehicle suddenly starts to move bakcward and it only stops if we swithc in to manual mode and put the throttle on middle (it switches in to hold mode but does not stop).
I read about steering mode but I could not get any thing and the question rose in my mind that does this mode supports reverse movement or it is only used for forward move?
