Problem with BLHeli Telemetry
Hello all,
Another problem, this time with the BLheli Telemetry.
I could make it work in some prototypes using a Tmotor 4 in 1 f45 ESC and FC matek f405 SD.
Now I am trying with another prototypes that use Cubes Orange and Blacks with mini carrier boards and the Same ESC’s. I followed https://ardupilot.org/copter/docs/common-dshot-blheli32-telemetry.html but no luck. Maybe is the Baudrate?
Hello, I still could not make it to work. I have done all that is in the guide but no luck.
Any help?
Usually problems are related to either not using the AUX outputs or setting SERVO_BLH_MASK wrongly
Have you got a .bin log or param file to look at?
Hello, thanks for the reply. What I have this time is a quadcopter and I set SERVO_BLH_AUTO to 1. I am using the same parameters that worked for other quadcopters using a Tmotor 4 in 1 f45 ESC and FC matek f405 SD. The only change is now I am using a Cube on a small CB.
1.param (18.4 KB)
Here it is. Thanks for the help.
Set SERVO_BLH_MASK to 3840 - the problem is on the cube the IOMCU makes the motor mapping a little different.
Hello, I just dis and It does not work :frowning:
And the ESCs are connect to the AUX outputs?
No, they are connected to the normal 1,2,3,4 motor ports in the mini carrier board.
No support for BLHeli on those ports as they are connected to the IOMCU. I’m not sure how you get at the aux ports on the mini carrier board.
When you figure it out you also need to set the motors on SERVO9 - SERVO12 as those are for the aux outputs
I am using these port for something else already :confused:
Does it mean that I cannot use Dshot neither?
Correct
This is all documented in the wiki - did you try reading that?
Yes, I went trough the BLheli_32 telemetry and passthrough sections:
https://apm-wiki.drjlab.com/copter/docs/common-dshot-blheli32-telemetry.html?highlight=blheli_32
https://apm-wiki.drjlab.com/copter/docs/common-blheli32-passthru.html?highlight=blheli_32
But I did not see anything saying that The cube with mini CB cant use it. Could you please indicate me where should I read?
Those are not links to our wiki
Sorry,
I meant these 2:
https://ardupilot.org/copter/docs/common-blheli32-passthru.html?highlight=blheli_32
https://ardupilot.org/copter/docs/common-dshot-blheli32-telemetry.html?highlight=blheli_32
I do not know what the others are but they look like copies or the wiki or something
https://ardupilot.org/copter/docs/common-brushless-escs.html#mixing-esc-protocols
Thanks a lot.
I have set now the parameter
MOT_PWM_TYPE 1 For Oneshot
SERIAL2_PROTOCOL 16 Cause I am connecting the ESC telemetry wire to the RX of the telemetry 2
and
|SERVO_BLH_AUTO|1|
|SERVO_BLH_DEBUG|0|
|SERVO_BLH_MASK|0|
|SERVO_BLH_OTYPE|1|
|SERVO_BLH_POLES|14|
|SERVO_BLH_PORT|0|
|SERVO_BLH_REMASK|0|
|SERVO_BLH_TEST|0|
|SERVO_BLH_TMOUT|0|
|SERVO_BLH_TRATE|10|
I have seen that the passthrough only works if Im using Dshot, but should at least the telemetry work?
Nope telemetry requires dshot I am afraid
