22 12-31-1979 6-00-00 PM.bin (336 KB) 22 12-31-1979 6-00-00 PM.bin.log (618.9 KB)
I use Tmotor f80pro 2500 KV and Ultra F55A MINI 6S 4IN1 ESC. Batteries are 4000 mah 100C 4S and props are 6045.
The problem is when I suddenly increase the throttle input, the drone disarms. In think it should be related with the ESC. The receiver and the Matek FC are powered by a BEC from the battery, so they do not turn off. Only the ESC disarms. That does not happen if I increase gradually. I attach a log file.
Thanks in advance.
