Hi all,
I’m working on a Lua script for my Cube Orange+ autopilot. I want to read the parameters of a DO_SET_SERVO (MAV_CMD 183) command using Lua.
My approach is to check if the current mission command is DO_SET_SERVO like this:
local cmd_id = mission:get_current_do_cmd_id()
if cmd_id == 183 then
local command_time, param1, param2, param3, param4 = mission_receive()
if command_time then
gcs:send_text(6, "PWM: " .. param2)
else
gcs:send_text(6, "No mission_receive data yet")
end
end
Does not work. param2
is nil
Is mission_receive()
capable of reading DO_SET_SERVO
parameters when the command is sent manually? What is the correct way in Lua to catch live MAVLink DO_SET_SERVO commands?
Any advice would be greatly appreciated!
Thanks in advance!
