Hi all, I am currently using Pixhawk 2.4.8 and Mission Planner v4.0.3. However i am facing an issue with the logging failed issues but i cant figure out the problem.
I have tried a couple of different methods:
change SD card to 32GB
tried setting LOG_BACKEND_TYPE to File/Mavlink/Block and neither works.
Changing firmware to v4.0.1
Is there other solution methods I can try? Thanks in advance!
