Prearm: logging failed - Dakefpv H743 fc
Hello
Recently I start configuring my drone and I used Dakefpv fc with h743 chip. When I tried to arm it it shows me prearm logging failed. There is not sd card port in fc but it has internal 16MB memory for logs. What I can do about it?
I’ve tried all possible permutations of params, different firmware (including custom builds) and no luck. Same FC will load the data flash in Betaflight just fine. I suspect an error in the hardware mapping for this FC.
