i copied some parameter to other Fixedwings because all are the same model (ZMO V2 VTOL).
After I doing so, I get while arming the Unauthorized S/N error and can’t arming. Also after FORMAT_VERSION = 0.
What can I do now, when I dont have the firmware to installing it new?
Also I get the error with commpas calibration running. But when I check, no calibration is running. Also after completing it, I still get these error. Please help.
You can’t copy all the parameters from one to another. Calibrations and S/N data is per individual unit. You’ll likely need to reset the affected models and start over.
What flight controller is it? You should be able to re-flash it from MP.
This is likely a custom message by the manufacturer. It is not something output by standard ArduPilot firmware. Contact the manufacturer for help to reset.
