PreArm:CrashDump data detected -ArduPlane 4.6.2
HI,
report/ask about a problem for help:
I’m running ArduPlane 4.6.2 on a CUAV X7+ carrier board. Attached is crash_dump.bin file.
The first time it was powered on, everything was fine(The firmware version used at that time was 4.3.7,and all other hardware plugged into the arupilot);
After updating the firmware to 4.6.2,When I use the MP “Preflight Reboot Shutdown” function, the IMU LED light does not light up after the flight controller enters “bootloader”;But it can start normally using USB;And then,the problem starting.“PreArm:CrashDump data detected”
I unplugged all other hardware plugged into the flight controller, restarted it repeatedly, and occasionally reproduced the "The LED light does not light up after entering bootloader "
Very puzzling,so ,how to fix this?
crash_dump.bin (205.1 KB)
X7_4.6.2-20251027.param (22.0 KB)
By the way, can I analyze this log(crash_dump.bin) myself?How?
Analyzing Crash Dump
Good luck.
I’ve had a look, and this seems to be an issue with the GPS driver:
#0  0x00000000 in ?? ()
#1  0x08059550 in AP_GPS::pre_arm_checks (this=0x30003708 <plane+856>, failure_msg=failure_msg@entry=0x30001cb4 "",
    failure_msg_len=failure_msg_len@entry=100) at ../../libraries/AP_GPS/AP_GPS.cpp:1825
#2  0x080f75fa in AP_Arming::gps_checks (this=0x3000c614 <plane+37476>, report=<optimized out>)
    at ../../libraries/AP_Arming/AP_Arming.cpp:640
#3  0x080f896c in AP_Arming::pre_arm_checks (this=0x3000c614 <plane+37476>, report=<optimized out>)
    at ../../libraries/AP_Arming/AP_Arming.cpp:1611
#4  0x080f8b7c in AP_Arming::pre_arm_checks (this=this@entry=0x3000c614 <plane+37476>, report=report@entry=true)
    at ../../libraries/AP_Arming/AP_Arming.cpp:1680
#5  0x08022180 in AP_Arming_Plane::pre_arm_checks (display_failure=true, this=0x3000c614 <plane+37476>)
    at ../../ArduPlane/AP_Arming.cpp:67
#6  AP_Arming_Plane::pre_arm_checks (this=0x3000c614 <plane+37476>, display_failure=<optimized out>)
    at ../../ArduPlane/AP_Arming.cpp:47
#7  0x080b8b9e in GCS_MAVLINK::handle_command_run_prearm_checks (this=0x30024680, packet=...)
    at ../../libraries/GCS_MAVLink/GCS_Common.cpp:4781
#8  GCS_MAVLINK::handle_command_run_prearm_checks (packet=..., this=0x30024680) at ../../libraries/GCS_MAVLink/GCS_Common.cpp:4776
#9  GCS_MAVLINK::handle_command_int_packet (this=0x30024680, packet=..., msg=...)
    at ../../libraries/GCS_MAVLink/GCS_Common.cpp:5592
#10 0x080b56b6 in GCS_MAVLINK::try_command_long_as_command_int (this=this@entry=0x30024680, packet=..., msg=...)
    at ../../libraries/GCS_MAVLink/GCS_Common.cpp:5133
#11 0x080b5764 in GCS_MAVLINK::handle_command_long (this=0x30024680, msg=...) at ../../libraries/GCS_MAVLink/GCS_Common.cpp:5186
#12 0x080b50be in GCS_MAVLINK::update_receive (this=0x30024680, max_time_us=max_time_us@entry=1000)
    at ../../libraries/GCS_MAVLink/GCS_Common.cpp:1885
#13 0x080b6f1a in GCS_MAVLINK::update_receive (max_time_us=1000, this=<optimized out>) at ../../libraries/GCS_MAVLink/GCS.h:420
#14 GCS::update_receive (this=0x300092c8 <plane+24344>) at ../../libraries/GCS_MAVLink/GCS_Common.cpp:2705
#15 0x080a6cf4 in AP_Vehicle::scheduler_delay_callback () at ../../libraries/AP_Vehicle/AP_Vehicle.cpp:719
#16 0x0806526c in AP_HAL::Scheduler::call_delay_cb (this=0x300175cc <schedulerInstance>) at ../../libraries/AP_HAL/Scheduler.cpp:26
#17 0x0816bb64 in ChibiOS::Scheduler::delay (this=0x300175cc <schedulerInstance>, ms=<optimized out>)
    at ../../libraries/AP_HAL_ChibiOS/Scheduler.cpp:238
#18 0x08054664 in AP_Compass_IST8310::init (this=this@entry=0x300249f8) at ../../libraries/AP_Compass/AP_Compass_IST8310.cpp:130
#19 0x08054818 in AP_Compass_IST8310::probe (dev=..., force_external=<optimized out>, rotation=<optimized out>)
    at ../../libraries/AP_Compass/AP_Compass_IST8310.cpp:90
#20 0x080501ee in Compass::_probe_external_i2c_compasses (this=this@entry=0x30003cec <plane+2364>)
    at ../../libraries/AP_Compass/AP_Compass.cpp:1275
#21 0x08050d42 in Compass::_detect_backends (this=0x30003cec <plane+2364>) at ../../libraries/AP_Compass/AP_Compass.cpp:1404
#22 0x08051032 in Compass::init (this=0x30003cec <plane+2364>) at ../../libraries/AP_Compass/AP_Compass.cpp:845
#23 0x0803d346 in Plane::init_ardupilot (this=0x300033b0 <plane>) at ../../ArduPlane/system.cpp:66
#24 0x080a7258 in AP_Vehicle::setup (this=0x300033b0 <plane>) at ../../libraries/AP_Vehicle/AP_Vehicle.cpp:421
#25 0x08114658 in main_loop () at ../../libraries/AP_HAL_ChibiOS/HAL_ChibiOS_Class.cpp:256
#26 HAL_ChibiOS::run (this=<optimized out>, argc=<optimized out>, argv=<optimized out>, callbacks=0x300033b0 <plane>)
    at ../../libraries/AP_HAL_ChibiOS/HAL_ChibiOS_Class.cpp:354
#27 0x08023818 in main (argc=<optimized out>, argv=<optimized out>) at ../../ArduPlane/ArduPlane.cpp:1075
@Live can you please give us the bin log from the microSD card, and bin log for last successful flight
I suspect the problem is that a pre-arm request came in over mavlink before the GPS was detected. I think there is a fix for this in 4.7.x
ping @peterbarker
looks like this is fixed in 4.6.3, which is going out today
hi,It has flown normally by flashing the firmware again,After that problem, there are flight logs available.
excuse me,u mean that new firmware released today?
