PreArm: Battery 1 capacity failsafe critical >= lo
I have tried FW versions 4.5.7 and 4.6.0 Beta6. Both give the error msg -
almost immediately after powering up the FC (Matek H743WING).
The BATT_CAPACITY is 5000
the BATT_CRT_MAH is 1000
The displayed batt voltage is 16.3 and current is 1.2A
The only way I can get the message to go away and the craft to arm is to set the BATT_CRT_MAH to 0
What could be wrong?
I found an imperfect solution. If I set BATT_CRT_MAH to anything less than 1000, the error goes away.
That is normal. Your critical must be smaller than your BAT_LOW_MAH ( currently set at 1000)
