I setup a new quad copter , everything looks good but i cannot arm because always fail to pre arm with the msg logging not started, i already changed sd card to a brand new but still the same msg .
I know i can disable logging fail but i do not want ,so can someone help me to solve that problem.
That sounds all good.
I would then start to reduce logging options to just one or two. Try that and if it works it must be one particular option causing the issue.
…I guess you have GPS installed?
The only other thing to try would be using the LOG_FILE_RATE_MAX setting and try something like just 100 and once more test it. If it doesn’t change anything revert back to the default 0 value.
There is bound to be someone on here who has more experience with logging related issues than what I have.
Best of luck.
