Both uses the ATmega 328 p micro and the same firmware, so basically they are the same but the new includes the cables so you don’t need to solder anything.
I ended up doing the same thing. Though I did not try it, I was worried about the range of simply using the AR8000 satellite receiver connected to the spektrum port on the pixhawk. I have the AR8000/Satellite/PPM converter, and it works great.
@Flyhard,
The Spektrum Main Receivers do not have a PPM output. Only the Remote Receiver does. You have to use the Remote Receiver with the Pixhawk.
If you want to use the Spektrum Main Receiver with the Pixhawk, then you will have to purchase and use a PWM to PPM encoder.
Regards,
TCIII GM
To have super redundancy: can you have a binded satellite rx in the spektrum port of the pixhawk and in the same time have the main rx connected via ppm encoder? (That gives both main rx satellites and one satellite straight into the core of the pixhawk, should the main rx connection fail)
Yup, I have failsafe set up when i fly, and it works like a charm when tested, but it is a big and possibly expensive hazzle to abort missions with customers waiting, and loss of hardware is even more a hazzle. (E.g “land” mode straight down a pond or tree or RTL through telephone wires…) Therefore i’d like to know for sure if for example the RC connection on a Pixhawk is prioritized over the Spectrum/DSM port or vice versa or will not work at all.
