My ppm encoder has a 3 cable connector and 1 single cable connector. I know where the 3 cable connector goes to, but where do I plug the 1 single (grey) connector?
I’ve attach a picture…
Also currently I have to plug an external battery to my spectrum RX, is there a way to bypass this?
@totibross,
Your PPM encoder does not appear to be the same as the on in the 3DR store. Did you buy it from 3DR? If not then you need to ask whomever sold it to you what the purpose of the grey wire connector is.
