I finally got around to building my Tarot T960 hex with a 3DR APM 2.6 and was calibrating my ESCs without much success.
I was powering APM was from an external BEC through output pin #8 & JP1 installed on the APM.
I reset the power to the board by disconnecting the bec’s servo / power connector and reconnected.
Ever since that power reset I have NO “A” (red) LED activity at all…
I’ve tried disconnecting all accessories, jumpers and tried to power the unit from both BEC power and USB - all other LEDs have some activity - NONE on the “A” (red) led no matter what I do.
The boar shows up in wind’s devices as an Arduino Megs 2560 as it usually does but I cannot get a heartbeat in mission planner any longer.
Thanks for the info & schematic, that will come in handy I’m thinking
Unfortunately I doubt the APM is still under warranty, I bought the APM in Oct. 13 and for a bunch of reasons only got to building it now…
Good idea checking the BEC: I did check the BEC and it was outputting 5.22v and also powered the system for a couple dozen cycles and a few hours of operation without an incident before this one - so that wasn’t the issue…
I had reviewed the power requirements page a few times before and after this and all is in line with the requirements.
I ended up calling 3DR and talking with one of their techs, as it turns out the 3.3v regulator seems to be the culprit - It seems the regulator (TI TPS79133DBVT) has a habit of dying. Mine is only outputting 0.5v which is really weird - I’m now trying to figure out if I’m going to replace the board level unit or try an outboard 3.3v source after removing it from the board…
I expect I’ll remove the regulator from the board, supply 3.3v to the pin and see if the APM comes back to life, if it does I’ll order a replacement TI TPS79133DBVT and install it…
